Komponent Beskrivelse Antal 10K TRIM POTs 100 12C508P 8-Bit CMOS Microcontrollers 66 12C509A 8-Bit CMOS Microcontrollers 43 27C64A 8 X K CMOS EPROM 129 470K TRIM POTs 100 67L90 Termostat 3 BC517 NPN Darlington Transistor 8 BD337 Darlington Power Transistor 200 BDX77 Power Transistor 496 BR252W Diodebro 5 BR352 Diodebro 5 BT139 Triacs 26 BUZ 80A SIPMOS ® Power Transistor 8 BYR79 800 Ultra fast recovery rectifier diode 35 BYV42E Rectifier diodes 133 CD4023BE CMOS NAND GATE 350 CD4040BE BIN COUNTER DIVIDER 100 CD4044BE CMOS TRISTATE Latch 950 CD4049UBE CMOS Hex Buffer/ Converters 70 CD4067BE 16-Ch Analog MUX/DMUX 30 CNY17F-2 6-PIN DIP OPTOCOUPLERS FOR POWER SUPPLY 104 D8751H 8-BIT CONTROL-ORIENTED MICROCONTROLLERS 18 HCF4040BE BIN COUNTER DIVIDER 225 HE721A1210 Miniature Relay 9 HEF4024B 7-stage binary counter 650 JS12-K Relæer 12 L7805CV POSITIVE VOLTAGE REGULATORS 189 L7812CV POSITIVE VOLTAGE REGULATORS 16 LM339 Voltage Quad Comparators 125 MC14521BCP 24-Stage Frequency Divider 450 MOC3021 2350 Triac Driver Output Optocoupler 16 MOC3083 Optoisolaters TRIAC Driver 800 NE555N Single Timer 10 NEC 2501 902 MULTI PHOTOCOUPLER 8 P0102DB Sensitive gate SCR 5 SG3524N PULSE WIDTH REG 200 ST62T60C6 8-BIT OTP/EPROM MCUs 15 TD 300 IN 15V Triple IGBT/MOS Driver 6 TIC263 SILICON TRIACS 7 TNY255P Energy Efficient, Low Power Off-line Switchers 8 TOP202YAI Three-terminal Off-line PWM Switch 19 TOP204YAI Three-terminal Off-line PWM Switch 23 U111B Phase Control Circuit 2 U208B Open Loop Phase Control Circuit 1 U210B Phase Control Circuit 2 UAA4002 Control curcuit switching transistor 50 V23105-A5005-A201 Signal Relays 17 UP62 UCHIYA Carlo Gavassi termoføler 300 |
