Minimum/maximum (Læst 4770x)
Offline Elfix
  • Gammeldam
Minimum/maximum
« Dato: August 23, 2016, 08:22:02 »
Hej Forum
Så har jeg igen et problem med min vejrstation jeg kan bare ikke se fejlen i koden
for minimum temperatur når maximum temperatur virker det er i koden linje ca. 100
er der nogen her der kan hjælpe mig  ;)
Mvh Elfix
#include <SPI.h>           // used to communicated via the spi bus
#include <Ethernet.h>      // used to communicate with the ethernet controller
#include "TimerOne.h"          // Timer Interrupt set to 2 second for read sensors
#include <math.h>
#include <Wire.h>
#include <Adafruit_BMP085.h>
#define Bucket_Size 0.2794   // bucket size to trigger tip count
#define Bucket_Pin 3         // digital pin Bucket connected to
#define TX_Pin 8           // used to indicate web data tx
#define WindSensor_Pin (2)      // The pin location of the anemometer sensor
#define WindVane_Pin (A2)       // The pin the wind vane sensor is connected to
#define VaneOffset 70           // define the anemometer offset from magnetic north
Adafruit_BMP085 bmp;
volatile unsigned long tipCount;    // bucket tip counter used in interrupt routine
volatile unsigned long contactTime; // Timer to manage any contact bounce in interrupt routine
volatile unsigned int  timerCount;    // used to determine 2.5sec timer count
volatile unsigned long rotations;     // cup rotation counter used in interrupt routine
volatile unsigned long contactBounceTime;  // Timer to avoid contact bounce in interrupt routine
long lastTipcount;            // keeps track of bucket tips
float totalRainfall;       // total amount of rainfall detected
volatile float windSpeed;
int vaneValue;       // raw analog value from wind vane
int vaneDirection;   // translated 0 - 360 direction
int calDirection;    // converted value with offset applied
int lastDirValue;    // last recorded direction value
float minTemp;   // keeps track of the minimum recorded temp value
float maxTemp;   // keeps track of the maximum recorded temp value
float maxWind;   // keeps track of the maximum recorded wind value
// arayas we use for averaging sensor data
float temps[12];    // array of 12 temps to create a 2 minute average temp
float wspeeds[24];  // array of 24 wind speeds for 2 minute average wind speed
float wdirect[24];  // array of 24 wind directions for 2 minute average
// Here we setup the webserver. We need to supply a mac address. Some ethernet boards have a label attached
// with a mac address you can use.
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192,168,0,178);      // IP address, may need to change depending on network
EthernetServer server(80);           // create a server at port 80
void setup() {
  // setup rain sensor values
  lastTipcount = 0;
  tipCount = 0;
  totalRainfall = 0;
  // setup anemometer values
  lastDirValue = 0;
  rotations = 0;
  // setup timer values
  timerCount = 0;
  // disable the SD card by switching pin 4 high
  pinMode(4, OUTPUT);
  digitalWrite(4, HIGH);
  // start the Ethernet connection and the server:
  Ethernet.begin(mac, ip);
  server.begin();
  Serial.begin(9600);
if (!bmp.begin()) {
  Serial.println("Could not find a valid BMP085 sensor, check wiring!");
  while (1) {}
  pinMode(TX_Pin,OUTPUT);
  pinMode(Bucket_Pin, INPUT);
  digitalWrite(Bucket_Pin, HIGH);
  pinMode(WindSensor_Pin, INPUT);
  attachInterrupt(digitalPinToInterrupt(Bucket_Pin), isr_rg, FALLING);
  attachInterrupt(digitalPinToInterrupt(WindSensor_Pin), isr_rotation, FALLING);
  // Setup the timer intterupt for 0.5 second
  Timer1.initialize(500000);
  Timer1.attachInterrupt(isr_timer);
  sei();// Enable Interrupts
void loop() {
//  bmp.readSensor();
  // set temp min and max values
  if(bmp.readTemperature() < minTemp) {
    minTemp = bmp.readTemperature();
  if(bmp.readTemperature() > maxTemp) {
    maxTemp = bmp.readTemperature();
  // set wind max values
  if (windSpeed > maxWind) {
    maxWind = windSpeed;
  // update rainfall total if required
  if(tipCount != lastTipcount) {
    cli();  // disable intterupts
    lastTipcount = tipCount;
    totalRainfall = tipCount * Bucket_Size;
    sei();  // enable interrupts
  // listen for incoming clients
  EthernetClient client = server.available();
  if (client) {
    // an http request ends with a blank line
    boolean currentLineIsBlank = true;
    while (client.connected()) {
       if (client.available()) {
          char c = client.read();
          Serial.write(c);
          // if you've gotten to the end of the line (received a newline
          // character) and the line is blank, the http request has ended,
          // so you can send a reply
          if (c == '\n' && currentLineIsBlank) {
             // send a standard http response header
             digitalWrite(TX_Pin,HIGH);
             client.println("HTTP/1.1 200 OK");
             client.println("Content-Type: text/html");
             client.println("Connection: close");  // the connection will be closed after completion of the response
             client.println("Refresh: 10");  // refresh the page automatically every 5 sec
             client.println();
             client.println("<body bgcolor=\"black\">");//nye
             client.print("<font color=\"white\">");//nye
             client.println("<!DOCTYPE HTML>");
             client.println("<html><body><h1>&nbsp;&nbspGammeldam Weather Control<br>&nbsp;&nbsp vers. 1.0.1</h1>");
             digitalWrite(TX_Pin,HIGH);     // Turn the TX LED on
             client.print("<span style=\"font-size: 30px\";><br>&nbsp;&nbsp;Temperature is ");
             client.print(bmp.readTemperature());
             client.println(" &deg;C<br />");
             client.print("&nbsp;&nbsp;Minim ");
             client.print(minTemp);
             client.println(" &deg;C");
             client.print("&nbsp;&nbsp;Maxim ");
             client.print(maxTemp);
//             client.print("<br>&nbsp;&nbsp;Humidity is ");
//             client.print(bme.getHumidity());
//             client.println(" %<br />");
             client.print("<br>&nbsp;&nbsp;Pressure is ");
             client.print(bmp.readPressure()/100);
             client.println(" mb<br />");
             client.print("<br>&nbsp;&nbsp;Wind Speed is ");
             client.print(windSpeed);
             client.println(" ms<br />");
             client.print("&nbsp;&nbsp;");
             if(calDirection < 0.2)
             client.print("Quit wind");
             else if (windSpeed < 1.5)
             client.print("Almost calm Wind");
             else if (windSpeed < 3.3)
             client.print("Weak wind");
             else if (windSpeed < 5.4)
             client.print("Light wind");
             else if (windSpeed <7.9)
             client.print("Moderate breeze");
             else if (windSpeed < 10.7)
             client.print("Fresh wind");
             else if (windSpeed < 13.8)
             client.print("Strong wind");
             else if (windSpeed < 17.1)
             client.print("High wind");
             else if (windSpeed < 20.7)
             client.print("Moderate gale");
             else if (windSpeed < 24.4)
             client.print("Fresh gale");
             else if (windSpeed < 28.4)
             client.print("Storm");
             else if (windSpeed < 32.6)
             client.print("Strong storm");
             else
             client.print("Hurricane");
             client.println("<br />");
             client.print("<br>&nbsp;&nbsp;Wind Max Speed is ");
             client.print(maxWind);
             else if (maxWind < 1.5)
             else if (maxWind < 3.3)
             else if (maxWind < 5.4)
             else if (maxWind <7.9)
             else if (maxWind < 10.7)
             else if (maxWind < 13.8)
             else if (maxWind < 17.1)
             else if (maxWind < 20.7)
             else if (maxWind < 24.4)
             else if (maxWind < 28.4)
             else if (maxWind < 32.6)
             else
             getWindDirection();
             client.print("<br>&nbsp;&nbsp;Direction is ");
             client.print(calDirection);
             client.println(" &deg;");
             if(calDirection < 22)
             client.print(" = North");
             else if (calDirection < 67)
             client.print(" = NorthEast");
             else if (calDirection < 112)
             client.print(" = East");
             else if (calDirection < 157)
             client.print(" = SouthEast");
             else if (calDirection < 212)
             client.print(" = South");
             else if (calDirection < 247)
             client.print(" = SouthWest");
             else if (calDirection < 292)
             client.print(" = West");
             else if (calDirection < 337)
             client.print(" = NorthWest");
             else
             client.print(" = N");
             client.println(" <br />");
             client.print("<br>&nbsp;&nbsp;Rainfall is ");
             client.print(totalRainfall);
             client.println(" mm<br />");
             //client.print("&nbsp;&nbsp;Mini ");
             //client.print(minTemp);
             //client.println(" &deg;C<br />");
             //client.print("&nbsp;&nbsp;Maxi ");
             //client.print(maxTemp);
             client.println("</html>");
             digitalWrite(TX_Pin,LOW);      // Turn the TX LED off
             break;
           if (c == '\n') {
             // you're starting a new line
           } else if (c != '\r') {
             // you've gotten a character on the current line
             currentLineIsBlank = false;
    // give the web browser time to receive the data
    delay(1);
    // close the connection:
    client.stop();
    // Serial.println("client disconnected");
    Ethernet.maintain();
// isr routine for timer interrupt
void isr_timer() {
  timerCount++;
  if(timerCount == 5)
    // convert to ms using the formula 2.4 km/t = (2.4 km/t)*(1000 m/km)*(1/3600 t/s)
    // = 2/3 m/s = 0.667 m/s
    windSpeed = rotations * 0.667;
    rotations = 0;
    timerCount = 0;
// Interrrupt handler routine that is triggered when the rg-11 detects rain
void isr_rg() {
  if((millis() - contactTime) > 15 ) { // debounce of sensor signal
    tipCount++;
    contactTime = millis();
// end of rg-11 rain detection interrupt handler
// interrupt handler to increment the rotation count for wind speed
void isr_rotation ()   {
  if ((millis() - contactBounceTime) > 15 ) {  // debounce the switch contact.
    rotations++;
    contactBounceTime = millis();
// Get Wind Direction
void getWindDirection() {
   vaneValue = analogRead(WindVane_Pin);
   vaneDirection = map(vaneValue, 0, 1023, 0, 360);
   calDirection = vaneDirection + VaneOffset;
   if(calDirection > 360)
     calDirection = calDirection - 360;
   if(calDirection < 0)
     calDirection = calDirection + 360;
« Senest Redigeret: August 23, 2016, 14:21:58 af Elfix »
Sv: Minimum/maximum
« Svar #1 Dato: August 23, 2016, 17:24:03 »
Hej Jonny,
Du skriver:
float minTemp;
der er:
float minTemp = 0.0;
eller
minTemp = 0°C.
Jeg tror, det var ikke koldere end 0°C i dag. Så 0°C er korrekt.
Men hvis du skrive
float minTemp = 999.9;
er den næste værdi omkring 21.0°C ... og det virker.
Du kan også skrive
på enden af setup(); {..}
Apropos vejrstation ...
I tyskland har hver højtryksområde et navn. Og i denne uge heder det "gerd"
Offline Elfix
  • Gammeldam
Sv: Minimum/maximum
« Svar #2 Dato: August 23, 2016, 19:32:00 »
Hej Gerd
Tak for hjælpen!! også denne gang  :)
Nu skal jeg nok tænke på dig når der er solskin de næste dage   8)
Mvh Jonny
Offline Elfix
  • Gammeldam
Sv: Minimum/maximum
« Svar #3 Dato: August 23, 2016, 23:38:34 »
Hej Forum
Så mangler jeg bare at konverter det hele over til esp8266 med eller uden arduino også
google chart så tror jeg det køre  8)
Mvh Elfix
