Kæmpe projekt, Raspberry PI, Arduino MEGA 2560-R3 og en masse andet.
Startet af Danni-Hansen, April 01, 2012, 16:32:07
Det er, hvad jeg gjorde trin for trin:
Med:
lsusb
Jeg kan se min Arduino på ID 2341:0001
Bus 002 Device 005: ID 2341:0001
Og nu med:
sudo lsusb -v -d 2341:0001
jeg kan se:
iProduct er "Arduino" og
bcdDevice er 0.01
Har du versionen 0.01 ?? Det er versionen af Arduino firmware.
Nu, jeg starter Arduino IDE og programmer denne kode:
String command = "";
char c;
int val;
int ledPin = 13;                 // LED connected to digital pin 13
void setup() {
  pinMode(ledPin, OUTPUT);   // sets the digital pin as output
  Serial.begin(9600);        // opens serial port, sets data rate to 9600 bps
void loop() {
  // Check, if there is data in the receive buffer
  if (Serial.available() > 0) {
    // read the incoming character
    c = Serial.read();
    // It was a "ENTER", so decode the command
    if ((c=='\n') || (c=='\r')) {
      if (command == "L0") {
        Serial.println("gerd's Arduino: I will turn off the LED for you!");
        digitalWrite(ledPin, LOW);   // sets the LED off
      if (command == "L1") {
        Serial.println("gerd's Arduino: I will turn on the LED for you!");
        digitalWrite(ledPin, HIGH);   // sets the LED on
      if (command == "POT") {
        val = analogRead(0);    // read the input pin A0
        Serial.print("gerd's Arduino: The potentiometer value is: ");
        Serial.println(val,DEC);
      // Clear the command
      command = "";
    // if it was an other character, add this to the command string
    else if (command.length() < 32) {
      command = command +c;
Jeg afslutter IDE.
Med:
ls /dev/tty*
jeg kan se /dev/ttyACM0
Jeg starter en Terminal-Software. Jeg tage putty
putty
Serial Line: /dev/ttyACM0
Speed: 9600
Connection Type: Serial
Starte med "Open"
I putty, jeg sender en:
L1<ENTER>
Svaret er:
Jeg afslutter putty.
Nu, jeg downloader http://www.sebulli.com/forum/danni_server.c
Jeg skifter til mappen af danni_server.c.
.. kompilere det med:
gcc -o danni_server danni_server.c
og starter Server med:
./danni_server
Server starter med:
gerd@gerd-901:~/Documents/arduino$ ./danni_server
Danni's Arduino Server started ...
IP address is: 127.0.0.1
Jeg ikke afslutter Server !!
Nu jeg starter en ny Linux Console for Client
Jeg downloader http://www.sebulli.com/forum/danni_client.c
gcc -o danni_client danni_client.c
og starter Client med:
./danni_client POT
gerd@gerd-901:~/Documents/arduino$ ./danni_client POT
gerd's Arduino: The potentiometer value is: 558
Hej Gerd.
Skal lige se om jeg kan få tid i morgen til at prøve igen.
Jeg melder lige tilbage når jeg har kigget på det igen.
Stort TAK for hjælpen indtil videre. :)
32bit på bærbaren, 64 på stationæren hvad jeg lige husker af.. :)
Hej Danni,
Jeg har testet det på en anden PC med Linux. Og jeg har det samme problem.
Men hvis jeg tage en FTDI-Serial-Converter på pin RX,TX og GND, jeg har ingen problemer.
Har du en FTDI converter kabel mit 5V/3.3V spænding?
Hvis ikke, jeg har en og jeg behøver det ikke længere. Du kan have det, hvis du vil.
Send mig en besked med din adresse.
Hej Gerd.
Beklager min langsommelighed, jeg har haft travlt med at lakere gulve i min lejlighed.
Jeg sender lige en privat besked med det samme, har nemlig intet kabel :)
Jeg takker :)
Hej Danni,
Jeg har sendt det.
Her er databladet:
http://www.ftdichip.com/Support/Documents/DataSheets/Cables/DS_TTL-232R_CABLES.pdf
Tilslut:
PIN 1 (GND) - sort - med Arduino UNO  GND
PIN 4 (TXD) - orange - med Arduino UNO RXD <- 0
PIN 5 (RXD) - gul - med Arduino UNO TXD -> 1
Men du kan også starte med en ekko test:
Tilslut PIN 4 (TXD) orange med PIN 5 (RXD) gul.
Kan du se port ttyUSB0 med
ls /dev/tty* ??
Ændre softwaren: /dev/ttyACM0 -> /dev/ttyUSB0
