Har nogen brug for 5.500.000 kroner? (Læst 7326x)
« Dato: Juli 26, 2014, 19:23:14 »
Google og IEEE søger en idé til en kompakt 2kW inverter og har startet en konkurrence.
https://www.littleboxchallenge.com/
Sv: Har nogen brug for 5.500.000 kroner?
« Svar #1 Dato: Juli 26, 2014, 19:39:56 »
Jo tak! Dem kan man nok godt finde et hul at putte i! :)
« Svar #2 Dato: Juli 27, 2014, 11:09:05 »
Af ren nysgerrighed.
Hvor stor må enheden være da? :)
« Svar #3 Dato: Juli 27, 2014, 11:28:57 »
In brief, the other specifications are :
  • Must be able to handle up to 2 kVA loads
  • Must achieve a power density of equal to or greater than 50 W/in3
  • Must be able to handle loads with power factors from 0.7–1, leading and lagging in an islanded mode
  • Must be in a rectangular metal enclosure of no more than 40 in3
  • Will be taking in 450 V DC power in series with a 10 Ω resistor
  • Must output 240 V, 60 Hz AC single phase power
  • Must have a total harmonic distortion + noise on both voltage and current of < 5%
  • Must have an input ripple current of < 20%
  • Must have an input ripple voltage of < 3%
  • Must have a DC-AC efficiency of greater than 95%
  • Must maintain a temperature of no more than 60°C during operation everywhere on the outside of the device that can be touched.
  • Must conform to Electromagnetic Compliance standards as set out in FCC Part 15 B
  • Can not use any external source of cooling (e.g. water) other than air
  • Does not require galvanic isolation
40in3 er omkring 655ccm eller 85x85x85mm.
« Svar #4 Dato: Juli 28, 2014, 09:12:27 »
Det kunne da være et spændende fælles projekt her på sitet :)
« Svar #5 Dato: Juli 28, 2014, 09:50:56 »
elektronik-forum.dk: Total antal medlemmer: 677
5.500.000 / 677 = 8124 kr. (for alle)  ;)
« Svar #6 Dato: Juli 28, 2014, 10:13:12 »
Lyder ikke helt tosset!  ;D
« Svar #7 Dato: Juli 28, 2014, 11:28:27 »
Ups,
Undskyld ... en fejl i beregningen.
(5.500.000-5000000) / (677-1) = 739,65 kr. (for alle)
« Senest Redigeret: Juli 28, 2014, 12:15:47 af gerd »
Offline janengelbrecht
  • Antal brugbare Indlæg: 23
    • Personlig hjemmeside
« Svar #8 Dato: November 12, 2014, 19:17:44 »
Svaret er : Nej :) Har penge nok :P : En anden måde at sige på at der er en god grund til den høje præmie....projektet er ikke for skrigende kvinder og andre tøsedrenge :P Faktisk ret skrappe krav der vil trække tænder ud :P I den sammenhæng svarer præmien nok fint til det tidsforbrug der skal bruges :)
« Senest Redigeret: November 12, 2014, 19:22:48 af janengelbrecht »
