Masser af komponenter til salg - stk-vis eller i partier eller et hele ! (Læst 5048x)
Offline keldsor
Jeg har disse komponenter i overskud:
Komponent   Beskrivelse   Antal
10K   TRIM POTs   100
12C508P   8-Bit CMOS Microcontrollers   66
12C509A   8-Bit CMOS Microcontrollers   43
27C64A   8 X K CMOS EPROM   129
470K   TRIM POTs   100
67L90   Termostat   3
BC517   NPN Darlington Transistor   8
BD337   Darlington Power Transistor   200
BDX77   Power Transistor   496
BR252W   Diodebro   5
BR352   Diodebro   5
BT139   Triacs   26
BUZ 80A   SIPMOS ® Power Transistor   8
BYR79 800   Ultra fast recovery rectifier diode   35
BYV42E   Rectifier diodes   133
CD4023BE   CMOS NAND GATE   350
CD4040BE   BIN COUNTER DIVIDER   100
CD4044BE   CMOS TRISTATE Latch   950
CD4049UBE   CMOS Hex Buffer/ Converters   70
CD4067BE   16-Ch Analog MUX/DMUX   30
CNY17F-2   6-PIN DIP OPTOCOUPLERS FOR POWER SUPPLY   104
D8751H   8-BIT CONTROL-ORIENTED MICROCONTROLLERS   18
HCF4040BE   BIN COUNTER DIVIDER   225
HE721A1210   Miniature Relay   9
HEF4024B   7-stage binary counter   650
JS12-K   Relæer   12
L7805CV   POSITIVE VOLTAGE REGULATORS   189
L7812CV   POSITIVE VOLTAGE REGULATORS   16
LM339   Voltage Quad Comparators   125
MC14521BCP   24-Stage Frequency Divider   450
MOC3021 2350   Triac Driver Output Optocoupler   16
MOC3083   Optoisolaters TRIAC Driver    800
NE555N   Single Timer   10
NEC 2501 902   MULTI PHOTOCOUPLER   8
P0102DB   Sensitive gate SCR   5
SG3524N   PULSE WIDTH REG   200
ST62T60C6   8-BIT OTP/EPROM MCUs   15
TD 300 IN   15V Triple IGBT/MOS Driver   6
TIC263   SILICON TRIACS   7
TNY255P   Energy Efficient, Low Power Off-line Switchers   8
TOP202YAI   Three-terminal Off-line PWM Switch   19
TOP204YAI   Three-terminal Off-line PWM Switch   23
U111B   Phase Control Circuit   2
U208B   Open Loop Phase Control Circuit   1
U210B   Phase Control Circuit   2
UAA4002   Control curcuit switching transistor   50
V23105-A5005-A201   Signal Relays   17
UP62 UCHIYA   Carlo Gavassi termoføler   300
Skriv hvad du vil ha' - stk-vis
eller i del-partier
eller gi' et bud på det hele  :o
