ATmega328p (Arduino Uno) + HD44780 LCD Display (16x02) (Læst 4671x)
« Dato: Oktober 04, 2012, 14:10:11 »
Hej folkens.
Prøver at få mit LCD Display til at skrive 2 linjers kode, så den selv smider tekst ned på næste linje efter 16 tegn.
Som nævnt i overskriften, er der 2 linjer på displayet.
Jeg får dog nogle fejl på det:
lcd_serial.cpp: In function ‘void loop()’:
lcd_serial.cpp:37:7: error: ‘input’ was not declared in this scope
lcd_serial.cpp:39:9: error: ‘inputt’ was not declared in this scope
lcd_serial.cpp:43:15: error: ‘input’ was not declared in this scope
lcd_serial.cpp:44:8: error: ‘inputt’ was not declared in this scope
Koden ser således ud:
#include <LiquidCrystal.h>
// Connections:
// rs (LCD pin 4) to Arduino pin 12
// rw (LCD pin 5) to Arduino pin 11
// enable (LCD pin 6) to Arduino pin 10
// LCD pin 15 to Arduino pin 13
// LCD pins d4, d5, d6, d7 to Arduino pins 5, 4, 3, 2
LiquidCrystal lcd(12, 11, 10, 5, 4, 3, 2);
int backLight = 13;    // pin 13 will control the backlight
void setup(){
  pinMode(backLight, OUTPUT);
  digitalWrite(backLight, HIGH); // turn backlight on. Replace 'HIGH' with 'LOW' to turn it off.
    // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  // initialize the serial communications:
  Serial.begin(9600);
void loop()
  // when characters arrive over the serial port...
  if (Serial.available()) {
    // wait a bit for the entire message to arrive
    delay(100);
    // clear the screen
    lcd.clear();
    // read all the available characters
    while (Serial.available() > 0) {
      char tekst = Serial.read();
      input += tekst;
      if(input.length() > 16){
        inputt += tekst;
      // display each character to the LCD
    lcd.write(input);
    if(inputt.length() > 0){
     lcd.setCursor(0,1);
     lcd.write(inputt);
På forhånd undskylder jeg for at jeg er lidt forvirret fortiden. Så der kan være total mess-up i koden.
Sv: ATmega328p (Arduino Uno) + HD44780 LCD Display (16x02)
« Svar #1 Dato: Oktober 04, 2012, 17:10:14 »
Hej Danni,
der er 2 "data types" for tekst:
string og
String
string er en "char array" - det er bare en samling af tegn ( char []) .
String er en komfortabel klasse med mange funktioner.
http://arduino.cc/en/Reference/HomePage
For input.length() eller inputt += tekst du har brug for en String klasse.
Men lcd.write eller lcd.print vil gerne have en string ( bare tegn, char [] )
Med:
..... int backLight = 13;    // pin 13 will control the backlight
String input="";
String inputt="";
char charArray[17];
void setup(){
input og inputt er en String klasse og charArray er en samling af tegn.
I stedet for ..
lcd.write(input);
du kan  skrive:
input.toCharArray(charArray,16);
lcd.print(charArray);
Her er hele koden:
// Connections:
String input="";
String inputt="";
char charArray[17];
void setup(){
  lcd.begin(16, 2);
  Serial.begin(9600);
void loop()
    delay(100);
    // clear the screen
    lcd.clear();
      input += tekst;
        inputt += tekst;
     lcd.setCursor(0,1);
     inputt.toCharArray(charArray,16);
« Svar #2 Dato: Oktober 05, 2012, 22:51:08 »
Hej Gerd.
Fantastisk :D
Tak!! Skal have prøvet det af ved næste "lege time" ;) hehe
