Er der nogle der leger med esp8266 esp-12 (Læst 6505x)
« Dato: Februar 02, 2015, 19:14:39 »
Er her nogle der har erfaring med esp8266 esp-12??
Dette er f.eks et ESP01 Modul
http://www.ebay.com/itm/ESP8266-Serial-Esp-01-WIFI-Wireless-Transceiver-Module-Send-Receive-LWIP-AP-STA-/221589414478?pt=LH_DefaultDomain_0&hash=item3397c2224e
Prisen for sådan et er ca. 21 Kr.
Her er der lidt data, kopieret fra siden
ESP8266 is a highly integrated chip designed for the needs of a new connected world. It offers a complete and self-contained Wi-Fi networking solution, allowing it to either host the application or to offload all Wi-Fi networking functions from another application processor.
ESP8266 has powerful on-board processing and storage capabilities that allow it to be integrated with the sensors and other application specific devices through its GPIOs with minimal development up-front and minimal loading during runtime. Its high degree of on-chip integration allows for minimal external circuitry, and the entire solution, including front-end module, is designed to occupy minimal PCB area.
Features
SDIO 2.0, SPI, UART
32-pin QFN package
Integrated RF switch, balun, 24dBm PA, DCXO, and PMU
Integrated RISC processor, on-chip memory and external memory interfaces
Integrated MAC/baseband processors
Quality of Service management
I2S interface for high fidelity audio applications
On-chip low-dropout linear regulators for all internal supplies
Proprietary spurious-free clock generation architecture
Integrated WEP, TKIP, AES, and WAPI engines
Solutions
Supports APSD for optimal VoIP applications
Patented spurious noise cancellation algorithm for integration in SOC applications
Supports Bluetooth co-existence interface
Self-calibrated RF to ensure optimal performance under all operating conditions
Zero factory tuning
No external RF components
Specifications
802.11 b/g/n
Wi-Fi Direct (P2P), soft-AP
Integrated TCP/IP protocol stack
Integrated TR switch, balun, LNA, power amplifier and matching network
Integrated PLLs, regulators, DCXO and power management units
+19.5dBm output power in 802.11b mode
Power down leakage current of <10uA
Integrated low power 32-bit CPU could be used as application processor
SDIO 1.1/2.0, SPI, UART
STBC, 1×1 MIMO, 2×1 MIMO
A-MPDU & A-MSDU aggregation & 0.4ms guard interval
Wake up and transmit packets in < 2ms
Standby power consumption of < 1.0mW (DTIM3)
Hvis man ønsker nogle "større" moduler. Findes der f.eks ESP12
http://www.ebay.com/itm/Newest-ESP8266-Serial-Wireless-WIFI-Transceiver-Module-Send-Receive-ESP-12-/171588030981?pt=LH_DefaultDomain_0&hash=item27f3719205
Den har flere I/O porte, og koster ca. 28 kr.
Portene kan bruges som I/O, Interrupt, pwm, i2c, OW
Og man kan programmer dem til f.eks at være webserver.
Har bestilt to ESP12 som jeg glæder mig til at komme til at lege med.
Kunne nemt forstille mig at de kan bruges istedet for PIC kredsen i mit projekt, også bliver det udvidet med WIFI.
« Senest Redigeret: Februar 05, 2015, 12:36:47 af asm7100 »
